[GRASS-dev] [GRASS GIS] #2208: r.in.gdal/v.in.ogr: reprojection at import
trac at osgeo.org
Wed Mar 5 03:04:01 PST 2014
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: projection import gdal ogr | Platform: Unspecified
Cpu: Unspecified |
I would like to float the idea, in order to kick off a discussion: how
difficult would it be to implement reprojection at import, both in
r.in.gdal and v.in.ogr.
The simplest case would be the import of a data source with known and gdal
/ogr-recognizable projection system into a location with a different
projection. If the data source does not contain the info about its
projection, then the user would have to add that info.
This should complement, not replace the current system of reprojecting
from one location to another as this latter system allows more subtle
fine-tuning of the process.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2208>
