[GRASS-dev] [GRASS GIS] #2208: r.in.gdal/v.in.ogr: reprojection at import
trac at osgeo.org
Wed Mar 5 12:41:06 PST 2014
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: projection import gdal ogr | Platform: Unspecified
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:1 martinl]:
> reprojection option available for r.in.gdal/v.in.ogr would a step
forward from user perspective.
You would need to supply all options of [r|v].proj. Moreover, vector data
might need preprocessing (adding vertices to lines/boundaries) in order to
provide realistic and topologically correct results. The reprojection
option could IMHO be best implemented in a script which calls
r.in.gdal/v.in.ogr and then r.proj/(v.split + v.proj).
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/2208#comment:2>
