[GRASS-dev] [GRASS GIS] #2208: r.in.gdal/v.in.ogr: reprojection at import
trac at osgeo.org
Thu Mar 6 01:15:53 PST 2014
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: projection import gdal ogr | Platform: Unspecified
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:2 mmetz]:
> Replying to [comment:1 martinl]:
> > reprojection option available for r.in.gdal/v.in.ogr would a step
forward from user perspective.
> You would need to supply all options of [r|v].proj. Moreover, vector
data might need preprocessing (adding vertices to lines/boundaries) in
order to provide realistic and topologically correct results. The
reprojection option could IMHO be best implemented in a script which calls
r.in.gdal/v.in.ogr and then r.proj/(v.split + v.proj).
I had actually thought that it might be possible to integrate GDAL/OGR
library tools such as GDALWarpOperation and OGRCoordinateTransformation
directly into r.in.gdal/v.in.ogr.
But maybe you're right and we should not touch the general GRASS structure
of import into one location + reproject into another, and rather use a
wrapper.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2208#comment:3>
