[GRASS-dev] Fwd: Android Compilation
Vaclav Petras
wenzeslaus at gmail.com
Thu Mar 6 06:10:27 PST 2014
On Wed, Mar 5, 2014 at 11:46 PM, Yann Chemin <ychemin at gmail.com> wrote:
> I can find the 2 toolbox files in the
> /home/yann/dev/grass/dist.arm-unknown-linux-androideabi/etc/gui/wxpython/xml
> but they have 0 bytes...
> I guess that this is similar problem to the g.gui.* modules: wrong build
environment since on Mac OS X this is fixed by running the compilation of
gui/wxpython again within the GRASS session.
But this is probably not important because there is no way to wxPython on
Andriod. At least quick google search said so. So, perhaps GUI is the
biggest challange for Android (which could be to certain extent solved by
QGIS for Android bundled with GRASS for Android).
> On 6 March 2014 10:08, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> On Wed, Mar 5, 2014 at 11:23 PM, Yann Chemin <ychemin at gmail.com> wrote:
>>> Errors compiling only in
>>> /home/yann/dev/grass/gui/wxpython/animation
>>> /home/yann/dev/grass/gui/wxpython/mapswipe
>>> /home/yann/dev/grass/gui/wxpython/gmodeler
>>> /home/yann/dev/grass/gui/wxpython/rlisetup
>>> /home/yann/dev/grass/gui/wxpython/psmap
>>> /home/yann/dev/grass/gui/wxpython/dbmgr
>>> /home/yann/dev/grass/gui/wxpython/vdigit
>>> /home/yann/dev/grass/gui/wxpython/iclass
>>> /home/yann/dev/grass/gui/wxpython/gcp
>>> /home/yann/dev/grass/gui/wxpython/timeline
>> These (g.gui.* modules) are also problematic on Mac OS X. For me there is
>> no difference between these and standard scripts but there probably is
>> some. It seems that the build system is a bit fragile when it compiles
>> wxGUI things.
>> I'm wondering if toolboxes were generated
>> (etc/gui/wxpython/xml/menudata.xml and module_tree_menudata.xml).
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140306/0487d007/attachment-0001.html>
