[GRASS-dev] [GRASS GIS] #2210: unable to start GRASS GIS 7
GRASS GIS trac at osgeo.org
Mon Mar 10 03:45:49 PDT 2014
  Reporter:  turek   |       Owner:  grass-dev@…
      Type:  defect  |      Status:  reopened
  Priority:  normal  |   Milestone:  7.0.0
 Component:  Python  |     Version:  svn-trunk
Resolution:          |    Keywords:
  Platform:  Linux   |         Cpu:  x86-64
Comment(by turek):
 I still get the same error. Maybe I am doing something wrong however
 r59162 works for me:
 ostepok at ostepok-pc:~/Dev/GRASS/grass_wms/grass_trunk/lib/init$ svn up
 grass.py
 Updating 'grass.py':
 U    grass.py
 Updated to revision 59220.
 ostepok at ostepok-pc:~/Dev/GRASS/grass_wms/grass_trunk/lib/init$ make
 rm -f /home/ostepok/Dev/GRASS/grass_wms/grass_trunk/bin.x86_64-unknown-
 linux-gnu/grass70
 sed \
         -e
 's#@GISBASE@#/home/ostepok/Dev/GRASS/grass_wms/grass_trunk/dist.x86_64
 -unknown-linux-gnu#' \
         -e 's#@GRASS_VERSION_NUMBER@#7.0.svn#' \
         -e 's#@LD_LIBRARY_PATH_VAR@#LD_LIBRARY_PATH#' \
         -e 's#@START_UP@#grass70#' \
         -e 's#@CONFIG_PROJSHARE@#/usr/share/proj/#' \
         grass.py >
 /home/ostepok/Dev/GRASS/grass_wms/grass_trunk/bin.x86_64-unknown-linux-
 gnu/grass70
 chmod +x /home/ostepok/Dev/GRASS/grass_wms/grass_trunk/bin.x86_64-unknown-
 linux-gnu/grass70
 rm -f /home/ostepok/Dev/GRASS/grass_wms/grass_trunk/dist.x86_64-unknown-
 linux-gnu/grass70.tmp
 sed \
         -e 's#@GRASS_CONFIG_DIR@##' \
         grass.py >
 /home/ostepok/Dev/GRASS/grass_wms/grass_trunk/dist.x86_64-unknown-linux-
 gnu/grass70.tmp
 ../../bin.x86_64-unknown-linux-gnu/grass70
 Cleaning up temporary files...
 Starting GRASS GIS...
   File "/home/ostepok/Dev/GRASS/grass_wms/grass_trunk/dist.x86_64-unknown-
 linux-gnu/etc/gui/wxpython/gis_set.py", line 37, in <module>
     from core.utils import _
 linux-gnu/etc/gui/wxpython/core/utils.py", line 42, in <module>
     from core.gcmd  import RunCommand
 linux-gnu/etc/gui/wxpython/core/gcmd.py", line 744, in <module>
     _enc = GetDefaultEncoding() # define as global variable
 linux-gnu/etc/gui/wxpython/core/gcmd.py", line 737, in GetDefaultEncoding
     enc = locale.getdefaultlocale()[1]
   File "/usr/lib/python2.7/locale.py", line 511, in getdefaultlocale
     return _parse_localename(localename)
   File "/usr/lib/python2.7/locale.py", line 443, in _parse_localename
     raise ValueError, 'unknown locale: %s' % localename
 ValueError: unknown locale: None
 Error in GUI startup. If necessary, please report this error to the GRASS
 developers.
 Switching to text mode now.
 Hit RETURN to continue...
 Unable to create temporary directory </tmp/grass7-ostepok-7579>! Exiting.
 ostepok at ostepok-pc:~/Dev/GRASS/grass_wms/grass_trunk/lib/init$ svn up -r
 59162 grass.py
 U    grass.py
 Updated to revision 59162.
 linux-gnu/grass70
 sed \
         -e
         grass.py >
 gnu/grass70
 linux-gnu/grass70
 sed \
         grass.py >
 gnu/grass70.tmp
 Failed to set LC_ALL to None.UTF-8 (unsupported locale setting)
           __________  ___   __________    _______________
          / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
         / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
        / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
        \____/_/ |_/_/  |_/____/____/   \____/___//____/
 Note that I get this warning in r59162:
 Rest of source code is in r59220.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2210#comment:6>
