[GRASS-dev] [GRASS GIS] #2210: unable to start GRASS GIS 7
trac at osgeo.org
Sat Mar 15 01:41:55 PDT 2014
Reporter: turek | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: normal | Milestone: 7.0.0
Component: Python | Version: svn-trunk
Resolution: | Keywords:
Platform: Linux | Cpu: x86-64
Comment(by marisn):
I'm not able to reproduce the issue on my system no matter how hard I try.
Still the issue seems to be twofold - there was not robust enough code to
set language/locale in startup script. It is fixed and from r59215 it
should work just fine* The second problem is that now some problems with
other wxgui code have popped-up. I.e. getdefaultlocale shouldn't be used
to get encoding.
Can you, please, apply this patch and give me back output?
Index: lib/init/grass.py
--- lib/init/grass.py (revision 59254)
+++ lib/init/grass.py (working copy)
@@ -784,7 +784,10 @@
# Language override is disabled (system language specified)
# As by default program runs with C locale, but users expect to
# have their default locale, we'll just set default locale
- locale.setlocale(locale.LC_ALL, '')
+ try:
+ locale.setlocale(locale.LC_ALL, '')
+ except:
+ warning("Setting default locale failed. It indicates
misconfigured system. Check systems locale settings.")
if windows and os.getenv('LANG') is None:
language, encoding = locale.getdefaultlocale()
os.environ['LANG'] = language
@@ -1296,6 +1299,14 @@
# Subsequent functions are using _() calls and
# thus must be called only after Language has been set.
set_language()
+for lc in ('LC_CTYPE', 'LC_MESSAGES', 'LC_TIME', 'LC_COLLATE',
+ 'LC_MONETARY', 'LC_PAPER', 'LC_NAME', 'LC_ADDRESS',
+ 'LC_TELEPHONE', 'LC_MEASUREMENT', 'LC_IDENTIFICATION',
+ 'LANG', 'LANGUAGE', 'LC_ALL'):
+ if lc in os.environ:
+ print "%s = ' %s '" % (lc, os.environ[lc])
+ else:
+ print "%s = unset" % lc
# Create the temporary directory and session grassrc file
create_tmp()
* one of most common misconceptions of all programmers.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2210#comment:7>
