[GRASS-dev] Testing sample fire simulation data in GRASS 7
Markus Neteler neteler at osgeo.org
Tue Mar 11 07:53:02 PDT 2014
On Thu, Jan 2, 2014 at 12:25 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi,
> I wanted to test sample fire simulation data
> (http://grass.osgeo.org/download/sample-data/) in GRASS 7. I used the
> provided script and tried one command after each other (you cannot use the
> whole script because of r.spread X mon connection).
> However, the r.ros command is working only partially for me:
> GRASS 7.0.svn (fire_demolocation):~/... > r.ros -s model=fuel_model
> moisture_1h=1hour_moisture  moisture_live=live_moisture velocity=wind_speed
> direction=wind_direction slope=slope aspect=aspect elevation=elevation
> output=my_ros
>  100%
> ERROR: Invalid descriptor: 11
For the (ML) record: solved in 6.4, 6.5 and 7.svn.
Markus
