[GRASS-dev] pygrass: it is an error of mine?
Pietro peter.zamb at gmail.com
Wed Mar 12 08:01:14 PDT 2014
Hi Ivan,
On Wed, Mar 12, 2014 at 2:13 PM, Ivan Marchesini
<ivan.marchesini at gmail.com> wrote:
> Inside there are some nan and some float32 values.
> I would like to set the nans to 0.0
[cut]
> It seems that only the first row of the matrix is affected by the
> change..
I got the same problem trying to set to nan some values, so I think is
a bug in the RasterNumpy class, the weird thing is that it seems to
work for the first two lines...
I have no time to work on it at the moment.
Best regards
Pietro
