[GRASS-dev] [GRASS GIS] #2218: r.stream.order: lack of documentation for flow_accum column in attribute table
GRASS GIS trac at osgeo.org
Thu Mar 13 01:41:29 PDT 2014
table
 Reporter:  mlennert                   |       Owner:  grass-dev@…
     Type:  defect                     |      Status:  new
 Priority:  normal                     |   Milestone:  6.4.4
Component:  Addons                     |     Version:  unspecified
 Keywords:  r.stream.order flow_accum  |    Platform:  Unspecified
      Cpu:  Unspecified                |
 In NC data set:
 g.region rast=elevation
 r.watershed elevation thresh=10000 accum=accum
 r.stream.extract elevation="elevation" threshold=10000 stream_rast=streams
 direction=dir
 r.stream.order streams=streams dirs=dir vector=stream_order elev=elevation
 accum=accum
 stream_order attribute table now contains a column 'flow_accum'. There is
 no mention of this column in the man page. What exactly do the numbers in
 that column represent ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2218>
