[GRASS-dev] [GRASS GIS] #2219: wish: all modules that create a new map should put the module call into history
GRASS GIS trac at osgeo.org
Thu Mar 13 03:20:39 PDT 2014
history
 Reporter:  mlennert             |       Owner:  grass-dev@…
     Type:  enhancement          |      Status:  new
 Priority:  normal               |   Milestone:  7.0.0
Component:  Vector               |     Version:  svn-trunk
 Keywords:  history module call  |    Platform:  All
      Cpu:  Unspecified          |
Changes (by neteler):
  * platform:  Unspecified => All
  * component:  Default => Vector
Comment:
 This is the unfiltered list of vector commands potentially lacking
 Vect_hist_command():
 find vector/ -name "main.c" | xargs fgrep --files-without-match Vect_hist
 | grep -v v.out
 vector/v.convert/main.c
 vector/v.label/main.c
 vector/v.colors.out/main.c
 vector/v.to.rast/main.c
 vector/v.colors/main.c
 vector/v.vect.stats/main.c
 vector/v.what/main.c
 vector/v.lrs/v.lrs.where/main.c
 vector/v.lrs/v.lrs.label/main.c
 vector/v.lrs/v.lrs.create/main.c
 vector/v.lrs/v.lrs.segment/main.c
 vector/v.external.out/main.c
 vector/v.db.select/main.c
 vector/v.net.visibility/main.c
 vector/v.to.db/main.c
 vector/v.univar/main.c
 vector/v.kcv/main.c
 vector/v.label.sa/main.c
 vector/v.normal/main.c
 vector/v.surf.idw/main.c
 vector/v.neighbors/main.c
 vector/v.to.rast3/main.c
 vector/v.timestamp/main.c
 vector/v.class/main.c
 vector/v.build/main.c
 For some of them it will not be useful, reducing the remaining modules to
 a few.
 Which is most important for you?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2219#comment:1>
