[GRASS-dev] [GRASS GIS] #2219: wish: all modules that create a new map should put the module call into history
trac at osgeo.org
Thu Mar 13 09:25:19 PDT 2014
history
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: history module call | Platform: All
Cpu: Unspecified |
Comment(by mlennert):
Actually, I notice that my understanding was wrong: command history is
often written, but it is not displayed when you use v.info (aka Metadata
in the wxGUI), you have to explicitly as for v.info -h.
This is not the case for most raster modules, where you see the command
history with r.info, without the need for the -h flag.
Any reason for that difference ?
I think that creation command history is important enough to be part of
the "base" package of information delivered by the r/v.info commands.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2219#comment:2>
