[GRASS-dev] ideas for wxGUI development
Vaclav Petras
wenzeslaus at gmail.com
Tue Mar 18 08:38:44 PDT 2014
Hi, I'm just doing some histograms and the tools need to be revised. I'm
using the one which uses d.histogram but I always have to switch the font
manually to something more reasonable and the wxGUI-based histogram does
not look like histogram but it is default (context menu in lmgr).
matplotlib can help or just d.histogram is enough? I don't know, I was not
thinking about it much, so no exact idea.
Vaclav
On Tue, Mar 18, 2014 at 5:08 AM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi all,
> from time to time I have a student at the university who can program
> some compoment for wxGUI (currently looking for topics for two
> students). I got in my mind two ideas:
> 1) data catalog integrated into wxGUI Layer Manager as a new tab
> (simplified version) and as stand-alone application - ie. tool which
> enables to rename, copy and move maps across mapsets and locations
> (which would require in the most of cases reprojection), this tool
> would also allow to import external files including re-projection on
> the background, possibly also offer preview of data, in summary a tool
> similar to QGIS or ArcGIS catalog
> 2) interactive reclassification tool, something like ArcGIS reclass
> tool [1]. This dialog could be inspired by dialog for setting color
> rules interactively which is already available in GRASS.
> Do you have any other ideas (could be from easy to hard to implement
> range:-) ?
> Thanks for your comments in advance, Martin
> [1]
> http://www.le.ac.uk/ar/arcgis/Pictures/Practical_2/Reclassify%20tool.jpg
> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140318/487bcef3/attachment.html>
