[GRASS-dev] ideas for wxGUI development
Maris Nartiss
maris.gis at gmail.com
Tue Mar 18 13:33:27 PDT 2014
Track has many nice ideas on missing features. Some of them are good,
some - need a discussion.
http://trac.osgeo.org/grass/report/15?USER=anonymous&page=2
I would also add the idea of developing a solution for merging two (or
more) vector maps. The GUI tool is needed to set-up attribute table
mapping to allow of merging different columns into new ones. Still
currently there is also no C code module part to do the merge itself
based on produced rules.
Maris.
2014-03-18 17:38 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> Hi, I'm just doing some histograms and the tools need to be revised. I'm
> using the one which uses d.histogram but I always have to switch the font
> manually to something more reasonable and the wxGUI-based histogram does not
> look like histogram but it is default (context menu in lmgr). matplotlib can
> help or just d.histogram is enough? I don't know, I was not thinking about
> it much, so no exact idea.
> Vaclav
> On Tue, Mar 18, 2014 at 5:08 AM, Martin Landa <landa.martin at gmail.com>
> wrote:
>> Hi all,
>> from time to time I have a student at the university who can program
>> some compoment for wxGUI (currently looking for topics for two
>> students). I got in my mind two ideas:
>> 1) data catalog integrated into wxGUI Layer Manager as a new tab
>> (simplified version) and as stand-alone application - ie. tool which
>> enables to rename, copy and move maps across mapsets and locations
>> (which would require in the most of cases reprojection), this tool
>> would also allow to import external files including re-projection on
>> the background, possibly also offer preview of data, in summary a tool
>> similar to QGIS or ArcGIS catalog
>> 2) interactive reclassification tool, something like ArcGIS reclass
>> tool [1]. This dialog could be inspired by dialog for setting color
>> rules interactively which is already available in GRASS.
>> Do you have any other ideas (could be from easy to hard to implement
>> range:-) ?
>> Thanks for your comments in advance, Martin
>> [1]
>> http://www.le.ac.uk/ar/arcgis/Pictures/Practical_2/Reclassify%20tool.jpg
>> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
