[GRASS-dev] [GRASS GIS] #2223: v.buffer flags -s and -c not working(?)
trac at osgeo.org
Tue Mar 18 16:43:25 PDT 2014
Reporter: jbrauner | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.buffer | Platform: All
Cpu: Unspecified |
Hi devs,
browsed the dev and user lists and the trac for a while but came up with
zero results. Sorry, if this was already reported before.
In winGRASS (latest build) and Linux (ppa:grass/grass-devel) the -s (make
outside corners straigth) and -c (don't make caps at the end of lines)
flags don't seem to influence the result (still caps and round corners
everywhere). I've used the roadsmajor of the NC dataset with a buffer
distance of 1000.
In winGRASS6.4.3 and GRASS 6.4.2 (ubuntugis) it still works with the older
version of the NC dataset.
I've only raised one issue here for the time being - both flags seem to be
somehow related (to me ;)). If you prefer having two separate tickets,
please give me a hint.
I took a quick look at the sources - but I've no clue. Sorry.
If you need more info, please let me know. I just stumbled upon this
issue, it's no blocking issue here for me.
Cheers,
Johannes
Ticket URL: <https://trac.osgeo.org/grass/ticket/2223>
