[GRASS-dev] [GRASS GIS] #2226: Get python command from copy-button
GRASS GIS trac at osgeo.org
Mon Mar 24 01:42:55 PDT 2014
 Reporter:  jradinger    |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  unspecified
 Keywords:               |    Platform:  All
      Cpu:  Unspecified  |
 I typically try out my GRASS commands first via the GUI before I am using
 them my Python-scripts. Thus, it would greatly improve the workflow when
 the copy-button which is available for all modules in the GUI also exports
 the python command. At the moment only the shell command is copied to the
 clipboard. This could eventually be handled by introducing a new GRASS
 variable that can be used as a global switch if standard shell or python
 commands should be exported.
 Copying the python command with the GUI button would potentially also
 lower the barriers of using python for scripting for many other users.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2226>
