[GRASS-dev] [GRASS GIS] #1214: r.li.edgedensity: segmentation fault
GRASS GIS trac at osgeo.org
Mon Mar 24 04:46:12 PDT 2014
 Reporter:  neteler           |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  6.4.4
Component:  Raster            |     Version:  svn-releasebranch64
 Keywords:  r.li.edgedensity  |    Platform:  All
      Cpu:  x86-64            |
Changes (by neteler):
  * platform:  Linux => All
Comment:
 Replying to [comment:10 mmetz]:
 > Replying to [comment:9 neteler]:
 > > Replying to [comment:8 mmetz]:
 > > > Replying to [comment:7 neteler]:
 > > > > What is our backport policy here?
 > > > The r.li modules should be backported, or else the r.li modules
 should be deactivated in G6 because they are broken.
 > > > Do we want to keep the parallelization in G6?
 > > Since probably only "brute-force" backporting is possible (i.e.
 replace the
 > > current G6 version with trunk and then merge back the libgis calls),
 we
 > > will not be able to keep the parallelization in G6.
 > For the actual modules, I agree that a brute-force backport is the
 easiest solution.
 I have done so in r59304 (G6.5.svn) and in r59305 (G6.4.svn).
 Open issues: the modules r.li.dominance, r.li.pielou, r.li.renyi,
 r.li.shannon,
 r.li.simpson are not yet producing proper output. Since they appear to be
 similar
 among each other, there might be the same issue to be fixed in all.
 Help needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1214#comment:11>
