[GRASS-dev] [GRASS GIS] #2235: r.param.scale crashes during compile for revision 59387 on Ubuntu 12.0.4 x64
GRASS GIS trac at osgeo.org
Wed Mar 26 18:58:01 PDT 2014
x64
 Reporter:  dnewcomb  |       Owner:  grass-dev@…
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  Default   |     Version:  svn-trunk
 Keywords:            |    Platform:  Linux
      Cpu:  x86-64    |
 error in r.param.scale popped up while compiling revision:
  59387.Errors in:
 /usr/local/grass-7.0.svn/grass7_trunk/raster/r.param.scale
 cd to /usr/local/grass-7.0.svn/grass7_trunk/raster/r.param.scale amd make
 shows the following:
 make
 if [ "/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-linux-
 gnu/bin/r.param.scale" != "" ] ; then
 GISRC=/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-linux-
 gnu/demolocation/.grassrc70
 GISBASE=/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-linux-
 gnu PATH="/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-linux-
 gnu/bin:/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-linux-
 gnu/scripts:$PATH"
 PYTHONPATH="/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-
 linux-gnu/etc/python:/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64
 -unknown-linux-gnu/etc/python:$PYTHONPATH"
 LD_LIBRARY_PATH="/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64
 -unknown-linux-gnu/bin:/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64
 -unknown-linux-gnu/lib:/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64
 -unknown-linux-gnu/lib:" LC_ALL=C
 gnu/bin/r.param.scale --html-description < /dev/null | grep -v
 '</body>\|</html>' > r.param.scale.tmp.html ; fi
 *** buffer overflow detected ***:
 gnu/bin/r.param.scale terminated
 ======= Backtrace: =========
 /lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x37)[0x2b92f3022f47]
 /lib/x86_64-linux-gnu/libc.so.6(+0x109e40)[0x2b92f3021e40]
 /lib/x86_64-linux-gnu/libc.so.6(+0x1092a9)[0x2b92f30212a9]
 /lib/x86_64-linux-gnu/libc.so.6(_IO_default_xsputn+0xdd)[0x2b92f2f9413d]
 /lib/x86_64-linux-gnu/libc.so.6(_IO_vfprintf+0x3123)[0x2b92f2f63ae3]
 /lib/x86_64-linux-gnu/libc.so.6(__vsprintf_chk+0x94)[0x2b92f3021344]
 /lib/x86_64-linux-gnu/libc.so.6(__sprintf_chk+0x7d)[0x2b92f302128d]
 gnu/bin/r.param.scale(interface+0x136)[0x403716]
 gnu/bin/r.param.scale(main+0x9)[0x402379]
 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed)[0x2b92f2f3976d]
 gnu/bin/r.param.scale[0x4023e9]
 ======= Memory map: ========
 00400000-00407000 r-xp 00000000 08:01 2880678
 00606000-00607000 r--p 00006000 08:01 2880678
 00607000-00608000 rw-p 00007000 08:01 2880678
 00773000-00794000 rw-p 00000000 00:00 0
 [heap]
 2b92f2330000-2b92f2352000 r-xp 00000000 08:01 2002200
 /lib/x86_64-linux-gnu/ld-2.15.so
 2b92f2352000-2b92f2354000 rw-p 00000000 00:00 0
 2b92f2552000-2b92f2553000 r--p 00022000 08:01 2002200
 2b92f2553000-2b92f2555000 rw-p 00023000 08:01 2002200
 2b92f2558000-2b92f2567000 r-xp 00000000 08:01 2865459
 gnu/lib/libgrass_gmath.7.0.svn.so
 2b92f2567000-2b92f2766000 ---p 0000f000 08:01 2865459
 2b92f2766000-2b92f2767000 r--p 0000e000 08:01 2865459
 2b92f2767000-2b92f2768000 rw-p 0000f000 08:01 2865459
 2b92f2768000-2b92f2769000 rw-p 00000000 00:00 0
 2b92f2770000-2b92f2797000 r-xp 00000000 08:01 2863145
 gnu/lib/libgrass_raster.7.0.svn.so
 2b92f2797000-2b92f2996000 ---p 00027000 08:01 2863145
 2b92f2996000-2b92f2997000 r--p 00026000 08:01 2863145
 2b92f2997000-2b92f2998000 rw-p 00027000 08:01 2863145
 2b92f2998000-2b92f2999000 rw-p 00000000 00:00 0
 2b92f29a0000-2b92f29d6000 r-xp 00000000 08:01 2861276
 gnu/lib/libgrass_gis.7.0.svn.so
 2b92f29d6000-2b92f2bd5000 ---p 00036000 08:01 2861276
 2b92f2bd5000-2b92f2bd6000 r--p 00035000 08:01 2861276
 2b92f2bd6000-2b92f2bd7000 rw-p 00036000 08:01 2861276
 2b92f2bd7000-2b92f2bd9000 rw-p 00000000 00:00 0
 2b92f2c18000-2b92f2d13000 r-xp 00000000 08:01 2002199
 /lib/x86_64-linux-gnu/libm-2.15.so
 2b92f2d13000-2b92f2f12000 ---p 000fb000 08:01 2002199
 2b92f2f12000-2b92f2f13000 r--p 000fa000 08:01 2002199
 2b92f2f13000-2b92f2f14000 rw-p 000fb000 08:01 2002199
 2b92f2f14000-2b92f2f15000 rw-p 00000000 00:00 0
 2b92f2f18000-2b92f30cd000 r-xp 00000000 08:01 1976770
 /lib/x86_64-linux-gnu/libc-2.15.so
 2b92f30cd000-2b92f32cd000 ---p 001b5000 08:01 1976770
 2b92f32cd000-2b92f32d1000 r--p 001b5000 08:01 1976770
 2b92f32d1000-2b92f32d3000 rw-p 001b9000 08:01 1976770
 2b92f32d3000-2b92f32d8000 rw-p 00000000 00:00 0
 2b92f32d8000-2b92f3446000 r-xp 00000000 08:01 2230787
 /usr/lib/libfftw3.so.3.3.0
 2b92f3446000-2b92f3645000 ---p 0016e000 08:01 2230787
 2b92f3645000-2b92f3651000 r--p 0016d000 08:01 2230787
 2b92f3651000-2b92f3652000 rw-p 00179000 08:01 2230787
 2b92f3658000-2b92f3f63000 r-xp 00000000 08:01 2367606
 /usr/lib/atlas-base/atlas/liblapack.so.3gf.0
 2b92f3f63000-2b92f4163000 ---p 0090b000 08:01 2367606
 2b92f4163000-2b92f4168000 rw-p 0090b000 08:01 2367606
 2b92f4168000-2b92f4276000 rw-p 00000000 00:00 0
 2b92f4278000-2b92f45d8000 r-xp 00000000 08:01 2367605
 /usr/lib/atlas-base/atlas/libblas.so.3gf.0
 2b92f45d8000-2b92f47d8000 ---p 00360000 08:01 2367605
 2b92f47d8000-2b92f47e1000 rw-p 00360000 08:01 2367605
 2b92f47e8000-2b92f47f7000 r-xp 00000000 08:01 2864739
 gnu/lib/libgrass_ccmath.7.0.svn.so
 2b92f47f7000-2b92f49f6000 ---p 0000f000 08:01 2864739
 2b92f49f6000-2b92f49f7000 r--p 0000e000 08:01 2864739
 2b92f49f7000-2b92f49f8000 rw-p 0000f000 08:01 2864739
 2b92f49f8000-2b92f49fa000 r-xp 00000000 08:01 2002203
 /lib/x86_64-linux-gnu/libdl-2.15.so
 2b92f49fa000-2b92f4bfa000 ---p 00002000 08:01 2002203
 2b92f4bfa000-2b92f4bfb000 r--p 00002000 08:01 2002203
 2b92f4bfb000-2b92f4bfc000 rw-p 00003000 08:01 2002203
 2b92f4bfc000-2b92f4bfd000 rw-p 00000000 00:00 0
 2b92f4c00000-2b92f4c08000 r-xp 00000000 08:01 2854784
 gnu/lib/libgrass_datetime.7.0.svn.so
 2b92f4c08000-2b92f4e07000 ---p 00008000 08:01 2854784
 2b92f4e07000-2b92f4e08000 r--p 00007000 08:01 2854784
 2b92f4e08000-2b92f4e09000 rw-p 00008000 08:01 2854784
 2b92f4e10000-2b92f4e26000 r-xp 00000000 08:01 1981929
 /lib/x86_64-linux-gnu/libz.so.1.2.3.4
 2b92f4e26000-2b92f5025000 ---p 00016000 08:01 1981929
 2b92f5025000-2b92f5026000 r--p 00015000 08:01 1981929
 2b92f5026000-2b92f5027000 rw-p 00016000 08:01 1981929
 2b92f5027000-2b92f5028000 rw-p 00000000 00:00 0
 2b92f5028000-2b92f513c000 r-xp 00000000 08:01 2231027
 /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
 2b92f513c000-2b92f533c000 ---p 00114000 08:01 2231027
 2b92f533c000-2b92f533d000 r--p 00114000 08:01 2231027
 2b92f533d000-2b92f533f000 rw-p 00115000 08:01 2231027
 2b92f5340000-2b92f5355000 r-xp 00000000 08:01 1981923
 /lib/x86_64-linux-gnu/libgcc_s.so.1
 2b92f5355000-2b92f5554000 ---p 00015000 08:01 1981923
 2b92f5554000-2b92f5555000 r--p 00014000 08:01 1981923
 2b92f5555000-2b92f5556000 rw-p 00015000 08:01 1981923
 2b92f5558000-2b92f5570000 r-xp 00000000 08:01 2002197
 /lib/x86_64-linux-gnu/libpthread-2.15.so
 2b92f5570000-2b92f576f000 ---p 00018000 08:01 2002197
 2b92f576f000-2b92f5770000 r--p 00017000 08:01 2002197
 2b92f5770000-2b92f5771000 rw-p 00018000 08:01 2002197
 2b92f5771000-2b92f5776000 rw-p 00000000 00:00 0
 2b92f5778000-2b92f57ad000 r-xp 00000000 08:01 2232652
 /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
 2b92f57ad000-2b92f59ac000 ---p 00035000 08:01 2232652
 2b92f59ac000-2b92f59ad000 r--p 00034000 08:01 2232652
 2b92f59ad000-2b92f59ae000 rw-p 00035000 08:01 2232652
 2b92f59ae000-2b92f59b0000 rw-p 00000000 00:00 0
 7fff48fd8000-7fff48ff9000 rw-p 00000000 00:00 0
 [stack]
 7fff49000000-7fff49001000 r-xp 00000000 00:00 0
 [vdso]
 ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0
 [vsyscall]
 Aborted (core dumped)
 make: *** [r.param.scale.tmp.html] Error 1
 rm r.param.scale.tmp.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/2235>
