[GRASS-dev] [GRASS GIS] #2235: r.param.scale crashes during compile for revision 59387 on Ubuntu 12.0.4 x64
trac at osgeo.org
Wed Mar 26 21:59:44 PDT 2014
x64
Reporter: dnewcomb | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
Old description:
> error in r.param.scale popped up while compiling revision:
> 59387.Errors in:
> /usr/local/grass-7.0.svn/grass7_trunk/raster/r.param.scale
> cd to /usr/local/grass-7.0.svn/grass7_trunk/raster/r.param.scale amd make
> shows the following:
> make
> if [ "/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-linux-
> gnu/bin/r.param.scale" != "" ] ; then
> GISRC=/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-linux-
> gnu/demolocation/.grassrc70
> GISBASE=/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-linux-
> gnu PATH="/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-
> linux-gnu/bin:/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-
> linux-gnu/scripts:$PATH"
> PYTHONPATH="/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-
> linux-gnu/etc/python:/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64
> -unknown-linux-gnu/etc/python:$PYTHONPATH"
> LD_LIBRARY_PATH="/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64
> -unknown-linux-gnu/bin:/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64
> -unknown-linux-gnu/lib:/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64
> -unknown-linux-gnu/lib:" LC_ALL=C
> gnu/bin/r.param.scale --html-description < /dev/null | grep -v
> '</body>\|</html>' > r.param.scale.tmp.html ; fi
> *** buffer overflow detected ***:
> gnu/bin/r.param.scale terminated
> ======= Backtrace: =========
> /lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x37)[0x2b92f3022f47]
> /lib/x86_64-linux-gnu/libc.so.6(+0x109e40)[0x2b92f3021e40]
> /lib/x86_64-linux-gnu/libc.so.6(+0x1092a9)[0x2b92f30212a9]
> /lib/x86_64-linux-gnu/libc.so.6(_IO_default_xsputn+0xdd)[0x2b92f2f9413d]
> /lib/x86_64-linux-gnu/libc.so.6(_IO_vfprintf+0x3123)[0x2b92f2f63ae3]
> /lib/x86_64-linux-gnu/libc.so.6(__vsprintf_chk+0x94)[0x2b92f3021344]
> /lib/x86_64-linux-gnu/libc.so.6(__sprintf_chk+0x7d)[0x2b92f302128d]
> gnu/bin/r.param.scale(interface+0x136)[0x403716]
> gnu/bin/r.param.scale(main+0x9)[0x402379]
> /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed)[0x2b92f2f3976d]
> gnu/bin/r.param.scale[0x4023e9]
> ======= Memory map: ========
> 00400000-00407000 r-xp 00000000 08:01 2880678
> 00606000-00607000 r--p 00006000 08:01 2880678
> 00607000-00608000 rw-p 00007000 08:01 2880678
> 00773000-00794000 rw-p 00000000 00:00 0
> [heap]
> 2b92f2330000-2b92f2352000 r-xp 00000000 08:01 2002200
> /lib/x86_64-linux-gnu/ld-2.15.so
> 2b92f2352000-2b92f2354000 rw-p 00000000 00:00 0
> 2b92f2552000-2b92f2553000 r--p 00022000 08:01 2002200
> 2b92f2553000-2b92f2555000 rw-p 00023000 08:01 2002200
> 2b92f2558000-2b92f2567000 r-xp 00000000 08:01 2865459
> gnu/lib/libgrass_gmath.7.0.svn.so
> 2b92f2567000-2b92f2766000 ---p 0000f000 08:01 2865459
> 2b92f2766000-2b92f2767000 r--p 0000e000 08:01 2865459
> 2b92f2767000-2b92f2768000 rw-p 0000f000 08:01 2865459
> 2b92f2768000-2b92f2769000 rw-p 00000000 00:00 0
> 2b92f2770000-2b92f2797000 r-xp 00000000 08:01 2863145
> gnu/lib/libgrass_raster.7.0.svn.so
> 2b92f2797000-2b92f2996000 ---p 00027000 08:01 2863145
> 2b92f2996000-2b92f2997000 r--p 00026000 08:01 2863145
> 2b92f2997000-2b92f2998000 rw-p 00027000 08:01 2863145
> 2b92f2998000-2b92f2999000 rw-p 00000000 00:00 0
> 2b92f29a0000-2b92f29d6000 r-xp 00000000 08:01 2861276
> gnu/lib/libgrass_gis.7.0.svn.so
> 2b92f29d6000-2b92f2bd5000 ---p 00036000 08:01 2861276
> 2b92f2bd5000-2b92f2bd6000 r--p 00035000 08:01 2861276
> 2b92f2bd6000-2b92f2bd7000 rw-p 00036000 08:01 2861276
> 2b92f2bd7000-2b92f2bd9000 rw-p 00000000 00:00 0
> 2b92f2c18000-2b92f2d13000 r-xp 00000000 08:01 2002199
> /lib/x86_64-linux-gnu/libm-2.15.so
> 2b92f2d13000-2b92f2f12000 ---p 000fb000 08:01 2002199
> 2b92f2f12000-2b92f2f13000 r--p 000fa000 08:01 2002199
> 2b92f2f13000-2b92f2f14000 rw-p 000fb000 08:01 2002199
> 2b92f2f14000-2b92f2f15000 rw-p 00000000 00:00 0
> 2b92f2f18000-2b92f30cd000 r-xp 00000000 08:01 1976770
> /lib/x86_64-linux-gnu/libc-2.15.so
> 2b92f30cd000-2b92f32cd000 ---p 001b5000 08:01 1976770
> 2b92f32cd000-2b92f32d1000 r--p 001b5000 08:01 1976770
> 2b92f32d1000-2b92f32d3000 rw-p 001b9000 08:01 1976770
> 2b92f32d3000-2b92f32d8000 rw-p 00000000 00:00 0
> 2b92f32d8000-2b92f3446000 r-xp 00000000 08:01 2230787
> /usr/lib/libfftw3.so.3.3.0
> 2b92f3446000-2b92f3645000 ---p 0016e000 08:01 2230787
> 2b92f3645000-2b92f3651000 r--p 0016d000 08:01 2230787
> 2b92f3651000-2b92f3652000 rw-p 00179000 08:01 2230787
> 2b92f3658000-2b92f3f63000 r-xp 00000000 08:01 2367606
> /usr/lib/atlas-base/atlas/liblapack.so.3gf.0
> 2b92f3f63000-2b92f4163000 ---p 0090b000 08:01 2367606
> 2b92f4163000-2b92f4168000 rw-p 0090b000 08:01 2367606
> 2b92f4168000-2b92f4276000 rw-p 00000000 00:00 0
> 2b92f4278000-2b92f45d8000 r-xp 00000000 08:01 2367605
> /usr/lib/atlas-base/atlas/libblas.so.3gf.0
> 2b92f45d8000-2b92f47d8000 ---p 00360000 08:01 2367605
> 2b92f47d8000-2b92f47e1000 rw-p 00360000 08:01 2367605
> 2b92f47e8000-2b92f47f7000 r-xp 00000000 08:01 2864739
> gnu/lib/libgrass_ccmath.7.0.svn.so
> 2b92f47f7000-2b92f49f6000 ---p 0000f000 08:01 2864739
> 2b92f49f6000-2b92f49f7000 r--p 0000e000 08:01 2864739
> 2b92f49f7000-2b92f49f8000 rw-p 0000f000 08:01 2864739
> 2b92f49f8000-2b92f49fa000 r-xp 00000000 08:01 2002203
> /lib/x86_64-linux-gnu/libdl-2.15.so
> 2b92f49fa000-2b92f4bfa000 ---p 00002000 08:01 2002203
> 2b92f4bfa000-2b92f4bfb000 r--p 00002000 08:01 2002203
> 2b92f4bfb000-2b92f4bfc000 rw-p 00003000 08:01 2002203
> 2b92f4bfc000-2b92f4bfd000 rw-p 00000000 00:00 0
> 2b92f4c00000-2b92f4c08000 r-xp 00000000 08:01 2854784
> gnu/lib/libgrass_datetime.7.0.svn.so
> 2b92f4c08000-2b92f4e07000 ---p 00008000 08:01 2854784
> 2b92f4e07000-2b92f4e08000 r--p 00007000 08:01 2854784
> 2b92f4e08000-2b92f4e09000 rw-p 00008000 08:01 2854784
> 2b92f4e10000-2b92f4e26000 r-xp 00000000 08:01 1981929
> /lib/x86_64-linux-gnu/libz.so.1.2.3.4
> 2b92f4e26000-2b92f5025000 ---p 00016000 08:01 1981929
> 2b92f5025000-2b92f5026000 r--p 00015000 08:01 1981929
> 2b92f5026000-2b92f5027000 rw-p 00016000 08:01 1981929
> 2b92f5027000-2b92f5028000 rw-p 00000000 00:00 0
> 2b92f5028000-2b92f513c000 r-xp 00000000 08:01 2231027
> /usr/lib/x86_64-linux-gnu/libgfortran.so.3.0.0
> 2b92f513c000-2b92f533c000 ---p 00114000 08:01 2231027
> 2b92f533c000-2b92f533d000 r--p 00114000 08:01 2231027
> 2b92f533d000-2b92f533f000 rw-p 00115000 08:01 2231027
> 2b92f5340000-2b92f5355000 r-xp 00000000 08:01 1981923
> /lib/x86_64-linux-gnu/libgcc_s.so.1
> 2b92f5355000-2b92f5554000 ---p 00015000 08:01 1981923
> 2b92f5554000-2b92f5555000 r--p 00014000 08:01 1981923
> 2b92f5555000-2b92f5556000 rw-p 00015000 08:01 1981923
> 2b92f5558000-2b92f5570000 r-xp 00000000 08:01 2002197
> /lib/x86_64-linux-gnu/libpthread-2.15.so
> 2b92f5570000-2b92f576f000 ---p 00018000 08:01 2002197
> 2b92f576f000-2b92f5770000 r--p 00017000 08:01 2002197
> 2b92f5770000-2b92f5771000 rw-p 00018000 08:01 2002197
> 2b92f5771000-2b92f5776000 rw-p 00000000 00:00 0
> 2b92f5778000-2b92f57ad000 r-xp 00000000 08:01 2232652
> /usr/lib/x86_64-linux-gnu/libquadmath.so.0.0.0
> 2b92f57ad000-2b92f59ac000 ---p 00035000 08:01 2232652
> 2b92f59ac000-2b92f59ad000 r--p 00034000 08:01 2232652
> 2b92f59ad000-2b92f59ae000 rw-p 00035000 08:01 2232652
> 2b92f59ae000-2b92f59b0000 rw-p 00000000 00:00 0
> 7fff48fd8000-7fff48ff9000 rw-p 00000000 00:00 0
> [stack]
> 7fff49000000-7fff49001000 r-xp 00000000 00:00 0
> [vdso]
> ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0
> [vsyscall]
> Aborted (core dumped)
> make: *** [r.param.scale.tmp.html] Error 1
> rm r.param.scale.tmp.html
New description:
59387.Errors in:
make
gnu PATH="/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-linux-
gnu/bin:/usr/local/grass-7.0.svn/grass7_trunk/dist.x86_64-unknown-linux-
gnu/scripts:$PATH"
[heap]
[stack]
[vdso]
[vsyscall]
Comment(by hamish):
[formatting fix]
Ticket URL: <https://trac.osgeo.org/grass/ticket/2235#comment:1>
