[GRASS-dev] g.mremove: adding 'map name exclusion pattern' option
Markus Neteler
neteler at osgeo.org
Thu May 1 15:19:14 PDT 2014
On Mon, Mar 24, 2014 at 7:04 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Wed, Mar 19, 2014 at 7:14 AM, Paulo van Breugel <p.vanbreugel at gmail.com>
> wrote:
>> Would it be difficult to add an option to use 'map name exclusion
>> patterns' like is available in g.mlist?
> I'm always very confused when switching between g.mlist and g.mremove. The
> parameters are almost the same, yet different.
> g.mlist type=rast pattern="tmp_*"
> g.mremove rast="tmp_*"
In the past, there was some discussion about this with a longer answer
from Glynn:
http://lists.osgeo.org/pipermail/grass-dev/2008-October/040506.html
Markus
