[GRASS-dev] [GRASS-SVN] r60048 - grass/trunk/vector/v.in.db
Huidae Cho
grass4u at gmail.com
Fri May 2 14:19:06 PDT 2014
OK, I did a quick search and there are 104 calls to Vect_open_new. 63 calls
don't check its return value and 41 calls check. 27 of the 41 that do the
check do some cleaning work before finally throwing a fatal error. Most of
the cleaning work is Vect_close(already open vectors), which I don't think
is really necessary before throwing a fatal error. v.convert fcloses Digin
and v.surf.rst deletes left-over files. Even Vect_close returns 1. Based on
these observations, I think Vect_open_new needs to return what it's
returning now on failure and the 63 calls that don't check its return value
have to be fixed to avoid a potential segmentation fault. I'll fix them
tonight if I didn't overlook something.
53 files that don't check the return value:
./display/d.extract/main.c
./lib/sites/sites.c
./raster/r.carve/vect.c
./raster/r.contour/main.c
./raster/r.random/random.c
./raster/r.stream.extract/close.c
./raster/r.stream.order/stream_vector.c
./raster/r.stream.segment/stream_vector.c
./raster/r.stream.snap/points_io.c
./raster/r.to.vect/main.c
./raster/r.volume/main.c
./raster/simwe/simlib/output.c
./vector/v.buffer/main.c
./vector/v.build.polylines/main.c
./vector/v.build/main.c
./vector/v.clean/main.c
./vector/v.distance/main.c
./vector/v.drape/main.c
./vector/v.edit/main.c
./vector/v.external/main.c
./vector/v.extract/main.c
./vector/v.extrude/main.c
./vector/v.in.ascii/main.c
./vector/v.in.dwg/main.c
./vector/v.in.lidar/main.c
./vector/v.in.ogr/main.c
./vector/v.in.region/main.c
./vector/v.in.sites/main.c
./vector/v.kernel/main.c
./vector/v.lrs/v.lrs.create/main.c
./vector/v.lrs/v.lrs.label/main.c
./vector/v.lrs/v.lrs.segment/main.c
./vector/v.net.alloc/main.c
./vector/v.net.iso/main.c
./vector/v.net.salesman/main.c
./vector/v.net.steiner/main.c
./vector/v.overlay/main.c
./vector/v.parallel/main.c
./vector/v.patch/main.c
./vector/v.perturb/main.c
./vector/v.proj/main.c
./vector/v.qcount/main.c
./vector/v.reclass/main.c
./vector/v.rectify/main.c
./vector/v.sample/main.c
./vector/v.segment/main.c
./vector/v.select/main.c
./vector/v.split/main.c
./vector/v.surf.rst/main.c
./vector/v.to.points/main.c
./vector/v.transform/main.c
./vector/v.vol.rst/main.c
./vector/v.voronoi/main.c
On Fri, May 2, 2014 at 1:18 PM, Huidae Cho <grass4u at gmail.com> wrote:
> More detail.. When this happens, Map is not fully initialized and
> following Vect_* calls with Map can fail unexpectedly, which caused a
> segmentation fault in this case.
> On Fri, May 2, 2014 at 1:15 PM, Huidae Cho <grass4u at gmail.com> wrote:
>> Segmentation fault when you do v.in.db ... output=a at other_mapset because
>> Vect_open_new returns -1 with a warning, not a fatal error, "unable to
>> create new ... is not the current mapset". I didn't check why it's
>> returning -1 instead of throwing a fatal error in this case. I believe that
>> this warning has to be a fatal error if no modules rely on -1 return.
>> Huidae
>> On Fri, May 2, 2014 at 12:59 PM, Martin Landa <landa.martin at gmail.com>wrote:
>>> Hi,
>>> 2014-05-02 18:53 GMT+02:00 <svn_grass at osgeo.org>:
>>> > - Vect_open_new(&Map, outvect->answer, with_z);
>>> > + if (Vect_open_new(&Map, outvect->answer, with_z) == -1)
>>> > + exit(EXIT_FAILURE);
>>> please provide more info where it fails. Also note that Vect_open_new
>>> calls G_fatal_error() so the most of modules don't check return code
>>> of this function.
>>> Martin
>>> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140502/f6e19cce/attachment.html>
