[GRASS-dev] [GRASS-SVN] r60048 - grass/trunk/vector/v.in.db
Glynn Clements
glynn at gclements.plus.com
Sun May 4 00:23:43 PDT 2014
Huidae Cho wrote:
> OK, I did a quick search and there are 104 calls to Vect_open_new. 63 calls
> don't check its return value and 41 calls check.
This is the main reason why I replaced status returns with fatal
errors in much of lib/raster and lib/gis (r40209, r40217, r40701).
I propose that lib/vector takes the same approach (I didn't touch
lib/vector at the time because I'm not that familiar with it, and was
unsure as to its stability).
