[GRASS-dev] [GRASS GIS] #2279: wingrass71: rendering problems with raster layers automatically added by finished
GRASS GIS trac at osgeo.org
Sun May 4 02:08:24 PDT 2014
finished
 Reporter:  hellik               |       Owner:  grass-dev@…
     Type:  defect               |      Status:  new
 Priority:  critical             |   Milestone:  7.0.0
Component:  wxGUI                |     Version:  svn-trunk
 Keywords:  wingrass, rendering  |    Platform:  MSWindows 7
      Cpu:  x86-64               |
 taken from the dev-ML
 http://lists.osgeo.org/pipermail/grass-dev/2014-May/068633.html
 tested with winGRASS71 by osgeo4w from today.
 Rendering is activated in map display.
 start e.g. r.slope.aspect in the wxgui, define more than one outputs.
 Automatically adding the results to map display is activated.
 run r.slope.aspect, after the output results are added to map display,
 rendering has problems.
 -erase map display erases display, but rendering again raster artefacts
 are
 displayed
 - change raster color, raster artefacts are displayed
 -only after deleting from and readding result raster in map display,
 rendering is correct.
 anyone confirms this behavior?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279>
