[GRASS-dev] [GRASS GIS] #2279: wingrass71: rendering problems with raster layers automatically added by finished modules
trac at osgeo.org
Sun May 4 14:53:29 PDT 2014
finished modules
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: wingrass, rendering | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by hellik):
Replying to [comment:4 annakrat]:
> By artifacts you mean that you see different layers in map display and
in the layer manager? I had no problems with this on Ubuntu, I will try it
on Windows tomorrow.
have a look at the screenshots. this blue raster layer is the artefact.
this remains/persists although you toggle on/ off the several resultat
output maps automatically added to the map display by a finished module
like r.slope.aspect. it remains also if you zoom in/out.
only manually removing and adding again to map display helps.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:5>
