[GRASS-dev] [GRASS GIS] #2279: wingrass71: rendering problems with raster layers automatically added by finished modules
trac at osgeo.org
Mon May 5 07:32:35 PDT 2014
finished modules
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: wingrass, rendering | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by annakrat):
Replying to [comment:5 hellik]:
> Replying to [comment:4 annakrat]:
> > By artifacts you mean that you see different layers in map display and
in the layer manager? I had no problems with this on Ubuntu, I will try it
on Windows tomorrow.
> have a look at the screenshots. this blue raster layer is the artefact.
> this remains/persists although you toggle on/ off the several resultat
output maps automatically added to the map display by a finished module
like r.slope.aspect. it remains also if you zoom in/out.
no, toggle no/off worked for me, otherwise I can confirm it. It basically
doesn't show that the layer is checked when it is checked. I will try to
look at it this week.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2279#comment:6>
