[GRASS-dev] Multiple map frames in cartographic composer
Anna Petrášová kratochanna at gmail.com
Mon May 5 07:18:09 PDT 2014
ps.map doesn't support multiple map frames directly, only through eps
instruction:
http://grasswiki.osgeo.org/wiki/Psmap_multi_pane_example
Composer is just a graphical front-end to ps.map. It could run ps.map on
more map frames and display them via eps instruction (automate what the
user has to do) but it seems to be quite a lot of work. So, so far you have
to do it manually.
Anna
On Mon, May 5, 2014 at 7:14 AM, Paulo van Breugel <p.vanbreugel at gmail.com>wrote:
> Hi,
> I have no clue how difficult it would be to implement, but it would be
> great if there was the option in the cartographic composer to add more than
> one map frame (same goes for the other map items).
> Cheers,
> Paulo
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140505/31adbf28/attachment.html>
