[GRASS-dev] Multiple map frames in cartographic composer
Paulo van Breugel p.vanbreugel at gmail.com
Mon May 5 07:19:47 PDT 2014
Ok, thanks for the feedback.
On 5 May 2014 16:18, "Anna Petrášová" <kratochanna at gmail.com> wrote:
> Hi,
> ps.map doesn't support multiple map frames directly, only through eps
> instruction:
> http://grasswiki.osgeo.org/wiki/Psmap_multi_pane_example
> Composer is just a graphical front-end to ps.map. It could run ps.map on
> more map frames and display them via eps instruction (automate what the
> user has to do) but it seems to be quite a lot of work. So, so far you have
> to do it manually.
> Anna
> On Mon, May 5, 2014 at 7:14 AM, Paulo van Breugel <p.vanbreugel at gmail.com>wrote:
>> Hi,
>> I have no clue how difficult it would be to implement, but it would be
>> great if there was the option in the cartographic composer to add more than
>> one map frame (same goes for the other map items).
>> Cheers,
>> Paulo
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140505/f4735a5e/attachment.html>
