[GRASS-dev] [GRASS GIS] #1747: v.rast.stats on dbf shapefile not enough precision even with DOUBLE PRECISION
GRASS GIS trac at osgeo.org
Wed May 14 16:04:37 PDT 2014
PRECISION
  Reporter:  vesnikos  |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  normal    |   Milestone:  6.4.4
 Component:  Vector    |     Version:  6.4.2
Resolution:  fixed     |    Keywords:  v.rast.stats
  Platform:  Linux     |         Cpu:  x86-32
Changes (by neteler):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 In r57560 it got already changed to %.15g, so that looks like solved.
 Test case (long line broken by me for trac formatting):
 v.db.connect mysoils_wake -p
 g.copy vect=soils_wake,mysoils_wake
 v.rast.stats vector=mysoils_wake raster=slope colprefix=slope
 v.db.select mysoils_wake
 3364|120028|1653.86|35468|34409|Co|B|34|0.142551511526108|2.868412733078|
   2.7258612215519|1.10701639950275|0.692389694214987|0.479403488655124|
   62.5455679361202|37.6385575830936
 d.mon x0
 d.rast slope
 d.vect type=boundary
 To speed v.rast.stats up I added DB TRANSACTION in r60243, r60244.
 Closing as solved.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1747#comment:17>
