[GRASS-dev] [GRASS GIS] #2116: r.kappa: call to r.stats fails if spaces in path
trac at osgeo.org
Thu May 15 02:29:38 PDT 2014
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 6.4.4
Component: Raster | Version: svn-releasebranch64
Resolution: fixed | Keywords: r.kappa, path
Platform: Unspecified | Cpu: Unspecified
Changes (by mlennert):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:6 neteler]:
> Replying to [comment:5 glynn]:
> > Replying to [comment:4 mlennert]:
> > > I hadn't applied the patch, yet, since you suggested G_vspawn_ex(),
and I didn't find the time to look into that. Should that solution be
preferred ?
> > The spawn functions are preferable (that's what r.kappa uses in 7.0),
as they avoid the shell altogether.
> Backported to 6.5 in r60121 and to 6.4 in r60122. The result is
identical 7.0.
> Please test on Windows and close if solved.
Just tested on Windows 7 Virtual Machine with
WinGRASS-6.4.4svn-r60212-962-Setup.exe (yesterday's build) and GISDBASE
containing "GRASS DATA": it seems to work perfectly.
Closing.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2116#comment:7>
