[GRASS-dev] [GRASS GIS] #2229: error in projection definition
GRASS GIS trac at osgeo.org
Thu May 15 13:02:35 PDT 2014
 Reporter:  vincent             |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  normal              |   Milestone:  6.4.4
Component:  Projections/Datums  |     Version:  unspecified
 Keywords:                      |    Platform:  Unspecified
      Cpu:  Unspecified         |
Comment(by neteler):
 I cannot reproduce the problem with 6.4.svn r60122. Screenshot attached.
 My system is:
 System Info
 GRASS version: 6.4.4svn
 GRASS SVN Revision: 60122M
 GDAL/OGR: 1.10.1
 PROJ4: Rel. 4.8.0, 6 March 2012
 Python: 2.7.5
 wxPython: 2.8.12.0
 Platform: Linux-3.14.3-200.fc20.x86_64-x86_64-with-fedora-20-Heisenbug
 I also tested on the same machine GRASS 7.1.svn:
 grass71 -c epsg:3857 ~/grassdatum/test
 Cleaning up temporary files...
 Creating new GRASS GIS location/mapset...
 Welcome to GRASS 7.1.svn (r60176M)
 GRASS 7.1.svn (test):~ > g.proj -w
 PROJCS["Mercator",
     GEOGCS["wgs84",
         DATUM["WGS_1984",
             SPHEROID["WGS_1984",6378137,298.257223563]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Mercator_2SP"],
     PARAMETER["standard_parallel_1",0],
     PARAMETER["central_meridian",0],
     PARAMETER["false_easting",0],
     PARAMETER["false_northing",0],
     UNIT["Meter",1]]
 All fine, perhaps your PROJ.4 version is outdated?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2229#comment:1>
