[GRASS-dev] GRASS & QGIS: the future
Markus Neteler
neteler at osgeo.org
Fri May 30 12:47:50 PDT 2014
On Fri, May 30, 2014 at 9:33 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, May 30, 2014 at 12:38 AM, Glynn Clements
>> Committed in r60590.
>> The only aspect which might be invasive is that defs/gis.h now
>> includes <setjmp.h> for the jmp_buf declaration. Although this is a
>> standard C header, it's not necessarily as straightforward as other
>> headers, being tied to the compiler's internals. I would advise
>> checking whether there are any build issues on less-common platforms
>> (e.g. AIX) before promoting the change to release.
> I have patched my relbr7 locally on the AIX supercomputer and it compiles.
I should have added that I use gcc there. The change should be tested
with compilers as well.
Markus
