[GRASS-dev] [GRASS GIS] #2277: graphically set up region bounds
GRASS GIS trac at osgeo.org
Fri May 16 01:11:58 PDT 2014
  Reporter:  vincent      |       Owner:  martinl
      Type:  enhancement  |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  wxGUI        |     Version:  unspecified
Resolution:  fixed        |    Keywords:  region
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by mlennert):
 Replying to [comment:18 martinl]:
 > Replying to [comment:17 mlennert]:
 > > > Do you suggest to use this flag by default?
 > > Yes.
 > please try out r60251 (trunk).
 Doesn't work for me. I still get values such as;
 nsres:      9.9953005
 ewres:      9.99522706
 while working with the 10m resolution elevation data from the NC dataset.
 I've tried playing with the different constrain settings in the wxGUI
 MapDisplay ("Constrain display resolution to computational settings" and
 "Align region extent based on display size"), but no combination of the
 two seemed to do the trick.
 Does the GUI internally redefine the region for display and then applies
 that region in that call to g.region ?
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2277#comment:19>
