[GRASS-dev] [GRASS GIS] #2277: graphically set up region bounds
trac at osgeo.org
Fri May 16 01:58:05 PDT 2014
Reporter: vincent | Owner: martinl
Type: enhancement | Status: closed
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: unspecified
Resolution: fixed | Keywords: region
Platform: Unspecified | Cpu: Unspecified
Comment(by neteler):
Replying to [comment:19 mlennert]:
> Does the GUI internally redefine the region for display and then
> applies that region in that call to g.region ?
This reminds me of my question posted in grass-dev:
On Wed, Apr 16, 2014 at 6:09 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> when trying to render a large raster map with d.rast in the "command
> line version" (d.mon wx0), then it tries to use the current region
> which leads to a cairo memory error.
> It seems that the wxGUI is initializing the display in a more
> reasonable way to downsample the map to be rendered on the fly since
> it makes no sense to render it at original resolution. This "magic" is
> yet missing in d.mon.
> Where is that calculated in wxGUI to get an idea about the calculation
> of map display window size versus raster map size/resolution?
Maybe related, maybe not. In any case a resolution/region issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2277#comment:20>
