[GRASS-dev] [GRASS GIS] #2277: graphically set up region bounds
trac at osgeo.org
Sat May 17 15:33:27 PDT 2014
Reporter: vincent | Owner: martinl
Type: enhancement | Status: closed
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: unspecified
Resolution: fixed | Keywords: region
Platform: Unspecified | Cpu: Unspecified
Comment(by annakrat):
Replying to [comment:19 mlennert]:
> Replying to [comment:18 martinl]:
> > Replying to [comment:17 mlennert]:
> > > > Do you suggest to use this flag by default?
> > > Yes.
> > please try out r60251 (trunk).
> Doesn't work for me. I still get values such as;
> nsres: 9.9953005
> ewres: 9.99522706
> while working with the 10m resolution elevation data from the NC
dataset. I've tried playing with the different constrain settings in the
wxGUI MapDisplay ("Constrain display resolution to computational settings"
and "Align region extent based on display size"), but no combination of
the two seemed to do the trick.
> Does the GUI internally redefine the region for display and then applies
that region in that call to g.region ?
There is no GUI magic, just try to run this and you see that the -a flag
does nothing:
g.region -ap s=220660.881801 e=637854.596623 w=634055.347092
n=225295.966229
Apparently the -a flag requires the resolution parameter to be applied.
Please try r60300.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2277#comment:21>
