[GRASS-dev] [GRASS GIS] #1628: segfault in r.walk
GRASS GIS trac at osgeo.org
Fri May 16 05:23:49 PDT 2014
 Reporter:  pertusus        |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  normal          |   Milestone:  6.4.4
Component:  Raster          |     Version:  svn-releasebranch64
 Keywords:  r.cost, r.walk  |    Platform:  Linux
      Cpu:  x86-64          |
Comment(by mlennert):
 I tried with the test script and can confirm the crash. Testing a bit
 further the difference between the v.in.ascii and v.in.ogr imports, I saw
 that the latter has many more attribute columns. When I reduce the number
 of attribute columns, I get r.walk to work:
 v.info -c stop_points_ogr
 Displaying column types/names for database connection of layer 1:
 INTEGER|cat
 INTEGER|cat_point
 INTEGER|cat_relocated
 DOUBLE PRECISION|lon_relocated
 DOUBLE PRECISION|lat_relocated
 INTEGER|cat_
 DOUBLE PRECISION|value
 DOUBLE PRECISION|orig_lon
 DOUBLE PRECISION|orig_lat
 Running v.db.droptable before r.walk also makes r.walk work.
 I do not have the time right now to check if this is linked to a specific
 attribute or just the general number of attributes, but maybe someone else
 can continue on that path ?
 Backporting from grass7 seems quite invasive at this stage, unless the two
 modules are self-contained.
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/1628#comment:3>
