[GRASS-dev] [GRASS GIS] #2295: import of large shapefile in GRASS-db crashes 6.4.3 + 7.0 beta2
trac at osgeo.org
Fri May 16 06:28:04 PDT 2014
Reporter: janhuizinga | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.4
Component: Default | Version: 6.4.3
Keywords: | Platform: MSWindows 7
Cpu: Unspecified |
OS: Windows 7
GRASS versions: 6.4 + 7.0 beta2
I'm trying to import a shapefile containing 9,354,125 point of type 2.5D
in a GRASS-db. Size of this shapefile: 328MB for shp-file + 301MB for dbf-
file.
If I try to import it WITH creating an attribute table it only loads half
of the points and then exits with an error message (message attached
below). Size of coor-file in GRASS is then 173MB.
If I try to import the shapefile WITHOUT creating an attribute table it
fully converts the points, but reports an memory error during "Registering
primitives ..." Size of coor-file in GRASS is then 337MB (message attached
below)
Error messages in command console below:
error 1:
(Fri May 16 13:20:20 2014)
v.in.ogr dsn=D:\Users\HKV2\PR2820_Mego\JanH\Gebouwen3\adreslocatie.shp
layer=adreslocatie output=adreslocatie
Check if OGR layer <adreslocatie> contains polygons...
Importing 9354125 features (OGR layer <adreslocatie>)...
WARNING: System not initialized. Programmer forgot to call G_gisinit().
dbmi: Protocol error
ERROR: Cannot insert new row: insert into adreslocatie values ( 4802001,
'0363200000223289', '1011LH', 3, 300 )
(Fri May 16 13:28:58 2014) Command finished (8 min 38 sec)
error 2:
(Fri May 16 14:58:19 2014)
layer=adreslocatie output=adreslocatie --overwrite -t
WARNING: Vector map <adreslocatie> already exists and will be overwritten
WARNING: Table <adreslocatie> linked to vector map <adreslocatie> does not
exist
Building topology for vector map <adreslocatie at calc>...
Registering primitives...
Current region rows: 516, cols: 790
ERROR: G_realloc: unable to allocate 81480000 bytes of memory at
cindex.c:113
(Fri May 16 15:08:04 2014) Command finished (9 min 44 sec)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2295>
