[GRASS-dev] [GRASS GIS] #2293: MapSwipe query maps
GRASS GIS trac at osgeo.org
Sun May 18 11:41:19 PDT 2014
  Reporter:  lucadelu     |       Owner:  grass-dev@…
      Type:  enhancement  |      Status:  closed
  Priority:  normal       |   Milestone:  7.1.0
 Component:  wxGUI        |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  MapSwipe, query, wxGUI
  Platform:  All          |         Cpu:  Unspecified
Changes (by annakrat):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:2 lucadelu]:
 > Replying to [comment:1 annakrat]:
 > > I added query functionality in r60290. It displays query results from
 both windows together in one dialog since it was the easiest way to
 implement it. The dialog could have 2 trees of query results but that
 would require more changes.
 > Thanks Anna, it works perfectly.
 > I don't know if this feature should be backported to releasebranch 70.
 If not please close this ticket as fixed.
 Me neither. But I decided to backport (r60326) the querying so that it is
 easier to maintain Map Swipe bugfixes in both branches.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2293#comment:3>
