[GRASS-dev] [GRASS GIS] #2294: t.rast.aggregate: Name output rasters based on start-time
trac at osgeo.org
Fri May 16 00:09:02 PDT 2014
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: svn-trunk
Keywords: t.rast.aggregate | Platform: Unspecified
Cpu: Unspecified |
Using a numerical suffix for aggregated time series data makes it less
intuitive to use the results outside the TGRASS framework. One has to look
up the time stamp for e.g. a rastermap "temperature_avg_months_317" in
order to know which time periode it refers to (even those people who
produced it), while "temperature_avg_months_1989_09" already tells
something.
Please find attached a proposal for naming output rasters based on start
time - truncated according to granularity, implemented in a flag (s).
The attached patch is a modification of a patch I made for GRAS 7.0 wich I
currently use and where it works fine for absolute time datasets. Not sure
if it is suitable for relative or cyclic time though and it has not been
tested with GRASS 7.1. So it needs a critical review in any case.
I do not know if such a solution would be relevant for t.rast.accumulate
too (I have not used the module yet)...
If you find it useful I can send a patch for GRASS 7.0 too.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2294>
