[GRASS-dev] [GRASS GIS] #2298: r.stream.order hack= generates order 1 single pixels
trac at osgeo.org
Mon May 19 06:28:48 PDT 2014
Reporter: hcho | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Keywords: r.stream.order | Platform: Linux
Cpu: x86-64 |
Comment(by hellik):
Replying to [ticket:2298 hcho]:
> Running r.stream.order hack= assigns to single pixel tributaries order 1
instead of 2. I believe that any tributaries should get assigned order >=
2 and the main stream gets 1.
> I'm attaching screenshots of a streams and output hack raster maps. In
the streams map, the blue and green streams merge and flow into the gray
one. The gray stream has a small one pixel tributary coming in (center
lowest pixel) and this pixel becomes an order 1 (yellow) in the hack
output. I think this pixel should become 2 (green) because it's a
tributary to the gray main stream. I have a lot these single pixel
dangling tributaries and simply selecting order 1 doesn't make a nice
looking single polyline representing the main stream.
> Or maybe, I'm misunderstanding something in the Hack's order algorithm?
please provide the command producing this result.
are you using the optional?
accumulation=name
Name of input accumulation raster map
if not, can you rerun r.stream.order with using accumulation raster map?
thanks.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2298#comment:1>
