[GRASS-dev] [GRASS GIS] #2298: r.stream.order hack= generates order 1 single pixels
trac at osgeo.org
Mon May 19 10:29:12 PDT 2014
Reporter: hcho | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.1.0
Component: Raster | Version: svn-trunk
Keywords: r.stream.order | Platform: Linux
Cpu: x86-64 |
Comment(by hcho):
I used the following command:
r.stream.order stream_rast=streams direction=drain hack=streamshack
I didn't try it with the accumulation map, but it shouldn't make a
difference in theory, I think?
IMO, I got this problem because my streams raster has the single pixel
tributary and the module cannot handle it properly. If I try with the
accumulation map, it should work correctly because the accumulation map
covers the entire region. I'll try and let you know.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2298#comment:2>
