[GRASS-dev] gdal-grass plugin or support in gdal for GRASS 7
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Tue May 20 00:11:30 PDT 2014
Hei Paolo,
This is the relevant GDAL ticket:
http://trac.osgeo.org/gdal/ticket/2953
The GRASS plugin on http://download.osgeo.org/gdal/ has not been updated yet, but in the meantime you can rebuild GDAL against GRASS 7.
Workflow would be:
Build GDAL 1.11 without GRASS Support
Build GRASS (7) against GDAL 1.11
Build GDAL 1.11 with GRASS 7 support
Using that workflow, GDAL managed to read GRASS 7 raster data on my Ubuntu 12.04 LTS Server. However, I am not sure if the fixes by hcho have been merged into the 1.11 release (or the latest code yet). So maybe reading GRASS data using only GDAL could give incorrect results (incorrect window read?)...
Others please correct me if I am wrong...
Cheers
Stefan
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140520/6902c01a/attachment.html>
