[GRASS-dev] gdal-grass plugin or support in gdal for GRASS 7
Markus Neteler
neteler at osgeo.org
Tue May 20 01:25:26 PDT 2014
On Tue, May 20, 2014 at 9:11 AM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Hei Paolo,
> This is the relevant GDAL ticket:
> http://trac.osgeo.org/gdal/ticket/2953
> The GRASS plugin on http://download.osgeo.org/gdal/ has not been updated
> yet, but in the meantime you can rebuild GDAL against GRASS 7.
> Workflow would be:
> Build GDAL 1.11 without GRASS Support
> Build GRASS (7) against GDAL 1.11
> Build GDAL 1.11 with GRASS 7 support
You find that documented also here:
http://grasswiki.osgeo.org/wiki/Compile_and_install_GDAL-GRASS_plugin
Markus
