[GRASS-dev] gdal-grass plugin or support in gdal for GRASS 7
Paulo van Breugel
p.vanbreugel at gmail.com
Tue May 20 01:46:36 PDT 2014
Thanks, I know (I read) how to do this, but wasn't sure it is actually
working with GRASS 7. Happy to hear at least somebody managed :-). I
will give it a try then.
On 05/20/2014 10:25 AM, Markus Neteler wrote:
> On Tue, May 20, 2014 at 9:11 AM, Blumentrath, Stefan
> <Stefan.Blumentrath at nina.no> wrote:
>> Hei Paolo,
>> This is the relevant GDAL ticket:
>> http://trac.osgeo.org/gdal/ticket/2953
>> The GRASS plugin on http://download.osgeo.org/gdal/ has not been updated
>> yet, but in the meantime you can rebuild GDAL against GRASS 7.
>> Workflow would be:
>> Build GDAL 1.11 without GRASS Support
>> Build GRASS (7) against GDAL 1.11
>> Build GDAL 1.11 with GRASS 7 support
> You find that documented also here:
> http://grasswiki.osgeo.org/wiki/Compile_and_install_GDAL-GRASS_plugin
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140520/be1b3a67/attachment.html>
