[GRASS-dev] [cmbarton.wikidot.com] Contact via Wikidot.com
Michael Barton c.michael.barton at gmail.com
Wed May 21 08:15:37 PDT 2014
You have another Python installed in /opt in addition to the system Python. The computer is confused. You will need to change your path or python path to allow GRASS to use your system Python only. Also, the Mac binaries bundle wxPython with the program. You don't need to install this. If you have it, you should probably have exactly the same version that was used for compiling. Currently, I'm using 2.8.12.
Michael Barton
On May 21, 2014, at 4:27 PM, John Payne <jpayne at wcs.org> wrote:
> Hi Michael,
> Thank you very much for your help -- I just reinstalled it so that I could
> send you the error message (the installation always completes
> successfully) and here is the precise error message that I get when I try
> to run it (I get the same message with 7.0.beta2):
> Johns-MacBook-Pro:~ john$
> '/Applications/GRASS/GRASS-7.1.app/Contents/MacOS/grass.sh'; exit
> Rebuilding Addon HTML manual pages index...
> Rebuilding Addon menu...
> dyld: DYLD_ environment variables being ignored because main executable
> (/usr/bin/osascript) is code signed with entitlements
> Python 2.7.5 found.
> arch: posix_spawnp: /opt/local/bin/pythonw2.7: Bad CPU type in executable
> logout
> John
> On 5/20/14 1:11 AM, "Michael Barton" <c.michael.barton at gmail.com> wrote:
>> This is a weird error. I built these binaries against OS X 10.7 and am
>> sure that they work with Mavericks (10.9). But I only have Mavericks. So
>> I'm copying some of the GRASS developers in the hopes that someone else
>> can test.
>> Michael
>> On May 19, 2014, at 1:13 AM, Wikidot.com <sender at wikidot.com> wrote:
>>> Form data:
>>> First name, last name:
>>> John Payne
>>> Organization/Company:
>>> Wildlife Conservation Society
>>> Country:
>>> Mongolia
>>> Email:
>>> jcpayne at uw.edu
>>> Your message (5000 character max):
>>> Hi Michael, I just tried installing both of the binaries for Grass 7
>>> (7.0.beta2 and 7.1) on a new Mac (OS X 10.8.5), and got a message both
>>> times saying something like "Wrong operating system" (I since
>>> successfully installed 6.4, but I really need some of the new features
>>> of 7).  It wasn't clear to me from your release notes whether the
>>> binaries only worked for Mavericks.  Thanks,  John
