[GRASS-dev] [GRASS GIS] #2304: Problems with add category to all features workflow
trac at osgeo.org
Wed May 21 10:26:21 PDT 2014
Reporter: wenzeslaus | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: unspecified
Keywords: v.edit, v.category | Platform: Unspecified
Cpu: Unspecified |
This ticket contains several issues but they relates on to another and I
encountered them doing one thing. My goal was to set a new category to all
features in a vector map. I wanted all features to have the same category.
Prepare test data:
v.in.ascii input=- output=test separator=comma <<EOF
913240.0,250614.0
913250.0,250628.0
EOF
Check categories in tests data:
v.what map=test coordinates=913240.0,250614.0
East: 913240
North: 250614
Map: test
Mapset: jr_contours
Type: Point
Layer: 1
Category: 1
Try to add category to all features (using example in G7:v.edit manual but
leaving out `polygon` parameter for selection because we want all
features):
v.edit map=test3 tool=catadd layer=2 cats=10
A warning is generated but it still builds the topology:
Selecting features...
0 of 2 features selected from vector map <test3 at jr_sts_contours>
WARNING: No features selected, nothing to edit
Building topology for vector map <test3 at jr_sts_contours>...
Registering primitives...
2 primitives registered
2 vertices registered
Building areas...
100%
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
100%
Number of nodes: 0
Number of primitives: 2
Number of points: 2
Number of lines: 0
Number of boundaries: 0
Number of centroids: 0
Number of areas: 0
Number of isles: 0
v.edit complete.
For more complex map (a lot of lines) I got in this step:
0 of 56 features selected from vector map <contours_level_12 at jr_contours>
Building topology for vector map <contours_level_120 at jr_contours>...
v.edit: spindex_rw.c:1364: rtree_get_node: Assertion
`t->nb[level][which].n.level == level' failed.
However, something went wrong and spatial index is broken:
ERROR: Unable to open spatial index file for vector map
<test at jr_contours>
Building topology helps:
v.build map=test
Building topology for vector map <test at jr_contours>...
Building areas...
100%
0 areas built
0 isles built
100%
Number of nodes: 0
Number of points: 2
Number of lines: 0
Number of areas: 0
Number of isles: 0
Now we see that nothing changed in the map which was expected because no
features were selected:
East: 913240
North: 250614
Map: test
Mapset: jr_contours
Type: Point
Layer: 1
Category: 1
Since no features were selected last time, let's try to reverse selection
using `-r` flag. Note also that parameters `layer` and `cats` are in
section `Selection` in GUI but we will use them as input here.
v.edit -r map=test tool=catadd layer=2 cats=10
This selects all features which is what we want:
2 of 2 features selected from vector map <test at jr_contours>
2 features modified
Building areas...
100%
0 areas built
0 isles built
100%
Number of nodes: 0
Number of points: 2
Number of lines: 0
Number of areas: 0
Number of isles: 0
v.edit complete.
Result is OK, there is a layer 2 and our feature has category 10.
East: 913240
North: 250614
Map: test
Mapset: jr_contours
Type: Point
Layer: 1
Category: 1
Layer: 2
Category: 10
Check categories of all features using G7:r.category. Note that the
parameter which was called `tool` in G7:v.edit is called `option` in
G7:r.category:
v.category input=test option=report
Layer: 1
type count min max
point 2 1 2
all 2 1 2
Layer: 2
type count min max
point 2 10 10
all 2 10 10
v.category complete. 0 features modified.
Although G7:v.edit worked with categories, G7:v.category might be better.
For start, let's try example from manual (using the same testing data as
in previous case):
v.category input=test_5 output=test_5_step option=add step=5
Processing features...
Copying attribute table(s)...
Building topology for vector map <test_5_step at jr_contours>...
Building areas...
100%
0 areas built
0 isles built
100%
Number of nodes: 0
Number of points: 2
Number of lines: 0
Number of areas: 0
Number of isles: 0
0 features modified and report tells us that output contains categories
from 1 to 2:
v.category input=test_5_step option=report
Layer: 1
type count min max
point 2 1 2
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
face 0 0 0
kernel 0 0 0
all 2 1 2
What we actually want is to add a new category, same for all features:
v.category input=test_5 output=test_5_cat option=add cat=20
Building topology for vector map <test_5_cat at jr_contours>...
Building areas...
100%
0 areas built
0 isles built
100%
Number of nodes: 0
Number of points: 2
Number of lines: 0
Number of areas: 0
Number of isles: 0
0 features modified, and we still have category range 1-2:
v.category input=test_5_cat option=report
Layer: 1
type count min max
point 2 1 2
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
face 0 0 0
kernel 0 0 0
all 2 1 2
Since I'm actually patching multiple maps, I hoped that a note about
`v.category option=sum` in G7:v.patch manual will help me:
v.category input=test_5 output=test_5_sum option=sum cat=30
Building topology for vector map <test_5_sum at jr_sts_contours>...
Building areas...
100%
0 areas built
0 isles built
100%
Number of nodes: 0
Number of points: 2
Number of lines: 0
Number of areas: 0
Number of isles: 0
v.category complete. 2 features modified.
This is doing something, features were modified but it is of course
(according to G7:v.category manual) not what I want. It is `sum` is
''adding'' a value to a current category.
v.category input=test_5_sum option=report
Layer: 1
type count min max
point 2 31 32
line 0 0 0
boundary 0 0 0
centroid 0 0 0
area 0 0 0
face 0 0 0
kernel 0 0 0
all 2 31 32
Summary:
* it is not clear how to select all features in `v.edit`
* some parameters/options in `v.edit` have `guisection` Selection but
they can be used also as an input
* `v.edit` builds topology when there is nothing to edit
* `v.edit` breaks the topology/spatial index when the selection of
features was empty, ends with assert sometimes
* there is a space after map name in `v.what` output
* `v.category` has a parameter/option `option` while `v.edit` has a
parameter `tool`
* `v.category` builds topology when there was no change
* `v.category` does nothing for `option=step` and `option=add` using
`option=sum` under the same conditions gives a result if there is
something else to add, it is not in the example in manual
* `v.category` says `0 features modified.` when it finished `report` or
`print` but it seems redundant I wouldn't expect something else when using
`report` or `print` and not providing `output`
* if you will try to explore it using GUI query tool, you will see that
it shows only one layer and one category (it seems that underlying
`vector_what(map="...", coord=...)` and `v.what` works)
''We might create separate tickets from these but now I'm not sure what
are my mistakes, what is wrong documentation and how critical the bugs are
are or if they are just feature request.''
Ticket URL: <http://trac.osgeo.org/grass/ticket/2304>
