[GRASS-dev] [cmbarton.wikidot.com] Contact via Wikidot.com
William Kyngesburye
woklist at kyngchaos.com
Thu May 22 06:27:30 PDT 2014
The way the GRASS-Mac startup is configured, it looks for python in this order:
what's set in GRASS_PYTHON (full path to pythonw, needed for wxpython GUI)
what is found in the PATH (/opt is probably in your PATH)
the python.org Python (/Library/Frameworks)
the system python
It checks each for the python version needed, but not the architecture. the error you are getting is probably because GRASS needs to run python 32bit because of Wxpython limitations, but the /opt python is 64bit only. That's odd that macports does that since you need wxpython 3 to be able to run 64bit. But GRASS should have its own wxpython bundled, and it's best to use the python it was compiled for (system python as Michael said).
On May 22, 2014, at 4:31 AM, Michael Barton <c.michael.barton at gmail.com> wrote:
> I haven't installed PostGIS, so you'll have to ask William about that. But I do have Mavericks, GRASS 6 and 7, and QGIS v. 2 working together. I don't know how to best set the environment to use the system python. It is best to ask the list if someone has done this (copied here). OS X is a version of Unix, which is similar but not identical to Linux. Many of the configuration files for setting environmental variables are similar between OS X and Linux, but they can vary sometimes.
> Michael Barton
> On May 22, 2014, at 5:32 AM, John Payne <jpayne at wcs.org> wrote:
>> Hi Michael,
>> Thank you -- I remember reading about conflicts between multiple Python
>> versions but I don't know how to tell whether the /opt version is being
>> used by other software so I'm hesitant to remove it. I haven't switched
>> to Mavericks yet for fear that it would break things, but perhaps it's
>> time to take the plunge. It looks to me as though you and William
>> Kyngesbury have made it possible to install this combination:
>> Mavericks
>> PostgreSQL with PostGIS (postGIS is critical to me)
>> GRASS 7
>> QGIS
>> Šbut please tell me if that is not the case.
>> Also can you tell me which environment variable I need to change to "allow
>> GRASS to use the system Python only"? I hate to waste your time, but
>> being an ex-Windows user, these OS X installations seem like black magic
>> to me and the OS X books that I've seen are all way too general to be
>> useful ("push the big happy button and you're done!"). Maybe Unix books
>> are more useful? I'm guessing that experts like you simply learn the hard
>> way, by experience, but I would love to be able to study on my own if you
>> have any recommendations.
>> Lastly, I have been using MacPorts and I see that they have wxPython
>> version 2.8.12.1. Is that close enough to the one that you compiled with?
>> Thanks,
>> John
>> On 5/21/14 11:15 PM, "Michael Barton" <c.michael.barton at gmail.com> wrote:
>>> You have another Python installed in /opt in addition to the system
>>> Python. The computer is confused. You will need to change your path or
>>> python path to allow GRASS to use your system Python only. Also, the Mac
>>> binaries bundle wxPython with the program. You don't need to install
>>> this. If you have it, you should probably have exactly the same version
>>> that was used for compiling. Currently, I'm using 2.8.12.
>>> Michael Barton
>>> On May 21, 2014, at 4:27 PM, John Payne <jpayne at wcs.org> wrote:
>>>> Hi Michael,
>>>> Thank you very much for your help -- I just reinstalled it so that I
>>>> could
>>>> send you the error message (the installation always completes
>>>> successfully) and here is the precise error message that I get when I
>>>> try
>>>> to run it (I get the same message with 7.0.beta2):
>>>> Johns-MacBook-Pro:~ john$
>>>> '/Applications/GRASS/GRASS-7.1.app/Contents/MacOS/grass.sh'; exit
>>>> Rebuilding Addon HTML manual pages index...
>>>> Rebuilding Addon menu...
>>>> dyld: DYLD_ environment variables being ignored because main executable
>>>> (/usr/bin/osascript) is code signed with entitlements
>>>> Python 2.7.5 found.
>>>> arch: posix_spawnp: /opt/local/bin/pythonw2.7: Bad CPU type in
>>>> executable
>>>> logout
>>>> John
>>>> On 5/20/14 1:11 AM, "Michael Barton" <c.michael.barton at gmail.com> wrote:
>>>>> This is a weird error. I built these binaries against OS X 10.7 and am
>>>>> sure that they work with Mavericks (10.9). But I only have Mavericks.
>>>>> So
>>>>> I'm copying some of the GRASS developers in the hopes that someone else
>>>>> can test.
>>>>> Michael
>>>>> On May 19, 2014, at 1:13 AM, Wikidot.com <sender at wikidot.com> wrote:
>>>>>> Form data:
>>>>>> First name, last name:
>>>>>> John Payne
>>>>>> Organization/Company:
>>>>>> Wildlife Conservation Society
>>>>>> Country:
>>>>>> Mongolia
>>>>>> Email:
>>>>>> jcpayne at uw.edu
>>>>>> Your message (5000 character max):
>>>>>> Hi Michael, I just tried installing both of the binaries for Grass 7
>>>>>> (7.0.beta2 and 7.1) on a new Mac (OS X 10.8.5), and got a message both
>>>>>> times saying something like "Wrong operating system" (I since
>>>>>> successfully installed 6.4, but I really need some of the new features
>>>>>> of 7). It wasn't clear to me from your release notes whether the
>>>>>> binaries only worked for Mavericks. Thanks, John
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable. There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
