[GRASS-dev] libLAS on Ubuntu 14.04
Yann Chemin
ychemin at gmail.com
Thu May 22 17:47:05 PDT 2014
I can confirm the issue,
also by trying these configure options it is not helping:
--with-liblas --with-liblas-config
--with-liblas --with-liblas-config=/usr/bin/liblas-config
--with-liblas=yes --with-liblas-config
--with-liblas=yes --with-liblas-config=/usr/bin/liblas-config
Also two targets are found, both valid (v1.7.0) and identical:
whereis liblas-config
liblas-config: /usr/bin/liblas-config /usr/bin/X11/liblas-config
/usr/share/man/man1/liblas-config.1.gz
$ ls -aslh /usr/bin/X11/liblas-config
4.0K -rwxr-xr-x 1 root root 2.5K Feb 26 14:43 /usr/bin/X11/liblas-config
$ ls -aslh /usr/bin/liblas-config
4.0K -rwxr-xr-x 1 root root 2.5K Feb 26 14:43 /usr/bin/liblas-config
On 23/05/2014, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi,
> I was trying to compile GRASS with libLAS but ./configure says no.
> I used:
> and I have all liblas packages from standard Ubuntu 14.04 repository
> (libLAS version is 1.7.0 which is the current stable release).
> Since configure went OK but the result for libLAS was "no", I tried to
> compile and run the ./configure's testing code myself.
> Code:
> #include <liblas/capi/liblas.h>
> int main() {
> LASReader_Create("foo");
> ; return 0; }
> Compilation:
> gcc liblastest.c -o liblastest -ggdb -L/usr/lib -llas -llas_c
> -L/usr/lib/x86_64-linux-gnu
> /usr/lib/x86_64-linux-gnu/libboost_program_options.so.1.54.0
> /usr/lib/x86_64-linux-gnu/libboost_thread.so.1.54.0 /usr/lib/libgdal.so
> /usr/lib/libgeotiff.so /usr/lib/x86_64-linux-gnu/libtiff.so $(liblas-config
> --includes)
> Debugging test:
> gdb liblastest
> Starting program: /home/vasek/dev/grass/test/liblastest
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
> Program received signal SIGSEGV, Segmentation fault.
> 0x00007ffff7285471 in std::istream::seekg(std::fpos<__mbstate_t>) () from
> /usr/lib/x86_64-linux-gnu/libstdc++.so.6
> (gdb) bt
> #0 0x00007ffff7285471 in std::istream::seekg(std::fpos<__mbstate_t>) ()
> from /usr/lib/x86_64-linux-gnu/libstdc++.so.6
> #1 0x00007ffff759597b in liblas::detail::reader::Header::ReadHeader() ()
> from /usr/lib/liblas.so.2
> #2 0x00007ffff754713b in
> liblas::ReaderFactory::CreateWithStream(std::istream&) () from
> #3 0x00007ffff7bb1a80 in LASReader_Create () from /usr/lib/liblas_c.so.2
> #4 0x00000000004006ab in main () at liblastest.c:4
> So the test failed with segmentation fault but it would actually fail
> during compilation if I would use `liblas-config --libs` because the boost
> libraries are `libboost_program_options.so.1.54.0` on my computer while
> `liblas-config --libs` says just `libboost_program_options.so` (same for
> thread library).
> It seems that the thing with boost libraries is a packaging issue but I'm
> not sure about the other ones. I can repeat it outside GRASS I don't know
> if this is actually what GRASS is doing and if it makes sense.
> Was somebody successful with libLAS on Ubuntu 14.04 and what is the general
> procedure for Linux anyway?
> Thanks,
> Vaclav
