[GRASS-dev] G70: Link to PG database issue (wxGUI)
Martin Landa landa.martin at gmail.com
Sat May 24 13:40:02 PDT 2014
2014-05-24 10:06 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> OK, sure - the PG user name is different here. Would be cool to pop up
> this error message in the wxGUI somehow to get on the right track
> (maybe when the user attempts to select PG in the dropdown list?).
done in r60461 (wxGUI error), I have also added note about db.login
r60462 (trunk only). Ideally the wxGUI dialog should contain
user/passwd widget to enter the values directly without need to launch
db.login explicitly. Please feel free to fill enhancement ticket.
Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
