[GRASS-dev] problems building grass7_trunk on debian wheezy
epi
massimodisasha at gmail.com
Mon May 26 17:41:05 PDT 2014
i already did a make distclean then i posted the log
On May 26, 2014, at 8:37 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Mon, May 26, 2014 at 7:46 PM, epi <massimodisasha at gmail.com> wrote:
> Hi,
> trying to upgrade my grass7 installation i got errors for the following modules :
> v.kernel, v.net.path, v.to.db, m.measure
> Attached as gist the full build log for each module :
> https://gist.github.com/anonymous/cc53f782312fb347ee26
> for both v.to.db and m.measure the erros seems to be related to an undefined “G_units_to_meters_*”
> while v.kernel, v.net.path are pointing to problems in vect.h
> have you any clue ?
> Try to do make distclean. There were some changes in library. This usually requires distclean.
> Thanks for help.
> Massimo.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140526/2766856f/attachment.html>
