[GRASS-dev] problems building grass7_trunk on debian wheezy
epi
massimodisasha at gmail.com
Mon May 26 17:58:54 PDT 2014
there was a problem with "svn up” the trunk was not fully upgraded, because svn found the r.stream.* add ons inside the grass_trunk src directory
their presence was generating an svn conflict and aborting the upgrade.
I manually removed the add ons from trunk and did a complete svn up.
Now the build goes ahead without errors.
On May 26, 2014, at 8:41 PM, epi <massimodisasha at gmail.com> wrote:
> i already did a make distclean then i posted the log
> On May 26, 2014, at 8:37 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> On Mon, May 26, 2014 at 7:46 PM, epi <massimodisasha at gmail.com> wrote:
>> Hi,
>> trying to upgrade my grass7 installation i got errors for the following modules :
>> v.kernel, v.net.path, v.to.db, m.measure
>> Attached as gist the full build log for each module :
>> https://gist.github.com/anonymous/cc53f782312fb347ee26
>> for both v.to.db and m.measure the erros seems to be related to an undefined “G_units_to_meters_*”
>> while v.kernel, v.net.path are pointing to problems in vect.h
>> have you any clue ?
>> Try to do make distclean. There were some changes in library. This usually requires distclean.
>> Thanks for help.
>> Massimo.
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140526/c52e7740/attachment-0001.html>
