[GRASS-dev] g.mremove: adding 'map name exclusion pattern' option
Huidae Cho grass4u at gmail.com
Wed May 28 21:56:51 PDT 2014
Markus,
The more/less stop option is already in g.mlist through -p/-f flags. These
flags use the same code to output the same results.
Also, please check http://trac.osgeo.org/grass/ticket/2228. This version of
g.mremove has the same interface as g.mlist.
Huidae
On Sun, May 11, 2014 at 4:27 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, May 9, 2014 at 4:27 PM, Huidae Cho <grass4u at gmail.com> wrote:
> > I think it's good time to remove redundant modules and "sync" g.mlist and
> > g.mremove parameters before releasing 7.0. Are there missing features
> from
> > g.mlist/g.mremove that g.list/g.remove has?
> One difference is the "more/less" stop option in g.list.
> Perhaps g.list could become a Python wrapper around g.mlist and so on?
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140529/f63c4c7e/attachment-0001.html>
